File sync stalls for 60 seconds on about 10% of the files
ds00424
Postby ds00424 » Sun Nov 24, 2019 8:44 pm
Hi there.
I recently upgraded from 2013 to 2019 (running ver 14.0.1.1).
When I do file syncs I am seeing about 10% of the files stall for about 60 seconds and then resume. This happens on either the backup of the file or the copy of the file. I am syncing WebDav to FTP. Needless to say this is very annoying as it makes what should be a quick sync into many minutes. I just synced 88 files and it took about 10 minutes!
What debugging or other info can I provide to help identify the root cause of this issue?
David.
Re: File sync stalls for 60 seconds on about 10% of the files
Postby RiseFly » Mon Nov 25, 2019 10:30 am
This problem may be related to the response speed of the WebDAV or FTP server.
BestSync will not stall without reason.
ds00424
Postby ds00424 » Mon Nov 25, 2019 2:30 pm
Thanks for the quick reply.
I did not see this issue when using BestSync 2013 with the same WebDav and FTP endpoints.
There were some 'stalls' that occurred for a second or two. But never for 60s.
Again, is there some log or debug we can look at to determine the cause of these stalls.
With this issue, I consider the tool unusable.
David
Postby RiseFly » Tue Nov 26, 2019 10:20 am
You can start the preview of the task to see where BestSync stalls.
ds00424
Postby ds00424 » Tue Nov 26, 2019 4:36 pm
So seems like BestSync was in a bad state. I wanted to create a task to upload to a test area. So I did Edit/Copy an existing task but was unable to then paste. So i created a new task and after configuring each tab -- when i hit OK to save the task, BestSync crashed. When it came back up I had to re activate my license and the task i was creating did not exist. However, i was now able to copy/paste a task and a test task ran as expected uploading 98 files in about 10 seconds. I will keep an eye on this one. Thanks for your quick replies and advice.
Postby RiseFly » Wed Nov 27, 2019 8:18 am
BestSync newest version 14.0.1.6 has fixed a bug that may cause crash, please update to last version, the problem may have been fixed.
sanavigupta
Postby sanavigupta » Thu Nov 28, 2019 8:38 am
Great Post
ds00424
Postby ds00424 » Mon Dec 02, 2019 10:27 pm
Ah good. Thanks for the update.
I just saw it again on 14.0.1. So i uninstalled BS and then installed latest -- 14.0.1.6
Will let you know if I see this issue again. Seems like it has to run for a bit.
ds00424
Postby ds00424 » Tue Mar 31, 2020 2:40 pm
Hi again.
I have had 14.0.1.6 installed for a bit now and I am still seeing stalls for 60 seconds. I just did a sync of 7 files and it took nearly 5 minutes.
I am syncing between a Network share (local network) and an FTP server.
I have tried reducing the thread count to 4, thinking the FTP server was hitting max connections for the IP. but this did not help.
I tried NOT processing multiple files simultaneously, but still have the issue.
As far as I recall I started seeing this issue after upgrading from 2013
The following is in the last info in the message window when the sync was hanging one of the times. I don't see anything obvious.
<150 Accepted data connection
<226-File successfully transferred
<226 0.073 seconds (measured here), 126.24 Kbytes per second
>MFMT 20200326122934 _BS8_NT2A2NLKAPLAC_24E1_0C_00_MD5_B182CCA99E981DD636D04129C2DA7A03_MNZG63ROOBUHA.BS_.php
<213 UTIME OK
>PASV
<227 Entering Passive Mode (173,247,240,143,118,30)
>RETR _BS8_NT2A2NLKAPLAC_24E1_0C_00_MD5_B182CCA99E981DD636D04129C2DA7A03_MNZG63ROOBUHA.BS_.php
<150-Accepted data connection
<150 9.2 kbytes to download
<226 0.000 seconds (measured here), 97.83 Mbytes per second
in contrast, a sync to S3 has no issues.
If we cannot resolve this issue, i am going to have to use a different tool.
David
Postby RiseFly » Sat Apr 04, 2020 4:20 am
Because the task is synchronizing with FTP server, and FTP protocol uses multiple data ports, some of the ports may be blocked by firewall or anti-virus software.
Please refer to the following pages about how to setup the firewall settings when using FTP:
http://www.risefly.com/fseqna_ftp.htm
Users browsing this forum: No registered users and 8 guests
