				FTP Error
				Posted: Tue Apr 15, 2014 3:58 pm
				by empresar
				Hi
I'm experiencing some troubles when syncing files from a PC to the FTP account.  Preview shows many "FTP Error 425 Failed to create socket" so, it doesn´t compares such folders and files and then it doesn't sync those files.  It doesn't happen with all files but with some of them.  So  I can't find a pattern o logical cause of this problem.  I've tried many things like not procesing paralell synchronization option, changing to another FTP Server, but nothing happens.  I need some help.  I'm using BestSync 2014 - Ultimate License
				Re: FTP Error
				Posted: Tue Apr 15, 2014 11:38 pm
				The 425 error was the response from the server, it means the server can not connect to the client PC.
Please check if you have set the passive mode in the advanced setting when browsing the FTP folder.
And please check if you have setup the firewall setting correctly. Please refer to the following Q&A:
  How to set the firewall setting for FTP transfer?
http://www.risefly.com/fseqna_ftp.htm
				Re: FTP Error
				Posted: Wed Apr 16, 2014 1:38 pm
				by empresar
				It connects correctly to FTP server because doing a preview most files are attempted to be syncronized but in the same preview it shows some files whit that error message and usually are the same files while others has no problem in the same syncronization as you can see in the example attached where some files are correctly compared then some files or folders with ftp error message and then files correctly compared again and so on
				Re: FTP Error
				Posted: Thu Apr 17, 2014 12:46 pm
				At the bottom of the preview window, there log lines "425 Failed to create socket".
Because the error happened at the server end, please contact the developer of the server to see if they can give you any help.
				Re: FTP Error
				Posted: Thu Apr 17, 2014 2:32 pm
				by empresar
				Thanks.  But as I said, it happens with different FTP servers like FileZilla server, Windows FTPServer, Linux Server.  Could you give me any advice about what to check? because I've already checked what is in the FTP configuration tutorial
				Re: FTP Error
				Posted: Mon Apr 21, 2014 11:45 am
				FTP protocol needs to establish a data connection when listing files in a sub-folder, and the data connection  may use any port available.
If the port is not allowed by the firewall in server or client, then the connection is blocked, that causes "425 Failed to create socket".
Please check the firewall setting in the server side and client side, check following points:
  1. Add BestSyncApp.exe and BestSyncSvc.exe to the exception list of the firewall.
  2. Add Port 21 to the exception list of the firewall.
If passive mode is used:
  1. In FTP server side, set the port range used for the data channel.
  2. Add this port rang to the exception list of the firewall of the FTP server.
  3. Add this port rang to the exception list of the firewall of the client (where BestSync is installed).
If Active mode is used:
  1. Set the port range in “Option”/”Active Mode” of BestSync.
