Hi
I would like to know if bestsync can synchronize files that where created on a specific month and year until today (the present day), via an automated job. In a folder that belongs to an application are hundred of files since 2010 and I only need to sync files corresponding to 2013 and the daily files that are created. Can bestsync do this kind of sync? The sync is in one direction.
Thanks in advance
Victor D.
						How to sync files from specific month until today
Re: How to sync files from specific month until today
BestSync can not do this kind of thing automatically, but you can do it manually by selected the following option:
In the "Filter" tab, check "Only files changed after (in)" the following time (range) are synchronized", and select "Popup a dialog box to specify the time range" option.
Every time you start the task, the task pops up a dialog to let specify the time range. Only the files in this range will be synchronized.
Ok, excellent. Then I will trigger the process manually.
Thanks for your kindly help and attention
Kind regards
Victor David
Kind regards
Victor David
