Service wouldn't start and now can't re-install
Posted: Sat Sep 10, 2011 6:20 am
				Hi
I'm using 6.2.26 and running two tasks as a service. I noticed that I had some files out of sync and when I looked in the services applet I noticed that BestSync's wasn't running.
I tried to start it manually and it didn't work so I rebooted and it still didn't work.
Next step was to re-install with the "repair" option but I got an error "The installer was interrupted before BestSync could be installed. You need to restart the installer to try again."
At this point I thought it best to start from scratch so I un-installed and went for a fresh install. I got exactly the same error and can't get anywhere now.
I've tried to change the install path, the "Just me"/"Everyone" options but nothing works. I've always installed as an Administrator.
I've also manually started the install with an msiexec command line and set logging up. At one point the install pauses at which point the last few lines in the log are:
MSI (s) (CC:08) [06:54:48:103]: Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=1300000)
MSI (s) (CC:08) [06:54:48:103]: Executing op: ServiceInstall(Name=BestSyncSvc,DisplayName=BestSync Service,ImagePath="C:\Program Files\BestSync\BestSync 2011\BestSyncSvc.exe",ServiceType=16,StartType=2,ErrorControl=0,,Dependencies=[~],,,Password=**********,Description=To synchronize file with folders, FTP server, network drive.,,)
MSI (s) (CC:08) [06:54:49:610]: Executing op: ActionStart(Name=StartServices,Description=Starting services,Template=Service: [1])
MSI (s) (CC:08) [06:54:49:611]: Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=1300000)
MSI (s) (CC:08) [06:54:49:611]: Executing op: ServiceControl(,Name=BestSyncSvc,Action=1,Wait=0,)
30 seconds later the lines below are added (and a pile of others rolling back the install)
MSI (s) (CC:08) [06:55:20:022]: Note: 1: 2262 2: Error 3: -2147287038
Info 1920.Service 'BestSync Service' (BestSyncSvc) failed to start. Verify that you have sufficient privileges to start system services.
Action ended 06:55:20: InstallExecute. Return value 3.
MSI (s) (CC:08) [06:55:20:024]: User policy value 'DisableRollback' is 0
MSI (s) (CC:08) [06:55:20:024]: Machine policy value 'DisableRollback' is 0
I can see that the service installs in the services applet and as soon as it detects that the service can't start it removes the service and roles everything back.
The service is set to run as "Local System".
Has anybody else had this problem and what's the solution?
Philip
Philip
