Sync does not end.
Posted: Fri Sep 15, 2017 12:16 am
				You are using the FTP protocol to synchronize.
It's okay when I first sync.
However, the problem occurs from the second automatic synchronization.
Monitoring... (Notified:3403, Queued:7)
Progress Bar 100.00%
Time:Remain[72:00:00] , Used[1:46:51]
This state persists.
When I look at realtimeview, the file is OK every 5 seconds.
This is much slower than the first synchronization.
At this time, if a file change occurs
File synchronization does not work properly.
What setup should I do?
