Issue: Azure to Local Filesystem - Error Get Response
dualogic
Postby dualogic » Mon Jul 25, 2016 4:24 pm
Good day,
Out of 6 deployments of Bestsync (11.0.1.3) to regional sites which pulls from the same Azure container, but we have 2 sites that continue to error out with the following error: "Error get response (The connection with the server terminated abnormally)".
Now, can confirm when running the sync, Bestsync states its "Synchronizing"... "Scanning (xxxxx)"... Then it fails with the above error message.
I've tried to look up this error via this site along with Google, but I have turned up very little to explain why this error is happening.
Any suggestions would be welcomed to resolve this issue.
Re: Issue: Azure to Local Filesystem - Error Get Response
Postby RiseFly » Tue Jul 26, 2016 1:17 pm
Please try the new version 11.0.1.4 to see if the problem can be avoided.
The new version prolonged the timeout period when connects with Azure etc cloud storages.
dualogic
Postby dualogic » Tue Jul 26, 2016 7:38 pm
Thanks for the suggestion, unfortunately I end up with the exact same error with a slight different. When it does the "Scanning (xxxxx)" it starts at zero and stays there until it errors out with same issue: "Error get response (The connection with the server terminated abnormally)"
Anything else you can suggest?
Postby RiseFly » Thu Jul 28, 2016 1:17 pm
The error message indicates a loss of Internet connectivity.
Please take a look at your firewall/proxy to make sure it is not terminating the connection prematurely because it thinks there is no activity.
Bildebar
Contact:
Postby Bildebar » Wed Jan 18, 2017 6:44 am
> activity.
If it is terminating the connection early then what can we do to fix?
DerrickMcKibben
Contact:
Postby DerrickMcKibben » Sat May 25, 2019 8:58 pm
> > activity.
By setting this registry value, the Azure File Sync agent will accept any locally trusted SSL certificate when transferring data between the server and the cloud service.
FrankCloud
Postby FrankCloud » Tue Jul 30, 2019 5:06 pm
> cloud storages.
If it is a good version then really I will use it. I want to download it so can you please share the link.
FrankCloud
Postby FrankCloud » Tue Jul 30, 2019 5:10 pm
> > activity.
I also want to fix the problem because things are really fucked up.
Users browsing this forum: Bing [Bot] and 0 guests
