I deleted a large folder on both sides of the sync manually. It now seems to be stuck trying to delete on the mirror with 404 Not Found error on every run. The folder had 17,000 files in it and they all throw an errow. This makes it impossible to monitor actual successful rate. Using 10.0.0.3
 Beta
						404 Not Found
Re: 404 Not Found
If you delete the folder during synchronization, this issue may happen.
Please stop and start task, the problem should disappear.
Re: 404 Not Found
I did the delete before syncing. It appears all files deleted now, whether inside or by the sync, are staying in the list to sync and coming up Not Found on each subsequent sync run. It has happend on three runs in a row after restarting.
						Re: 404 Not Found
Could you please export the task to a .xfsi file, then send the file to risefly@risefly.com? so that we can find what is wrong.
