Run a task automatically without windows log in and not usin
modaxe
Post by modaxe »
I am trying to run the task automatically once machine started without user log in. I know you can set the task to run as windows service which will not require windows log in privileged.
However, is there another way to start the task automatically apart from making it as windows service.
The version i am using is 6.1.0.8(32Bit)
Thanks,
Re: Run a task automatically without windows log in and not
If you need the task be ran without user logon, you must select the task running as windows service, no other method.
