Is there a way to only sync NEW files?
mfragoso731
Post by mfragoso731 »
I have a folder with several thousand images and I only add several hundred in one shot but when I go to sync it takes many hours because it's syncing the whole folder, every time.
Any help would be greatly appreciated.
Re: Is there a way to only sync NEW files?
Please confirm if you are using the lastest version. We have just fixed a problem relate to this problem in version 7.0.21. (When sync with ftp and detecting timezone is not selected, or unable to.detect the timezone ).
mfragoso731
Using version Ver6.2.2.6(64Bit)
mfragoso731
Ok I installed the newest version.
How do I set it up to only sync NEW files?
BestSync is designed for sync only new/changed files, upgrade to the new version, and start the preview of the task, you can confirm if only new/changed files are to be synchronized.
mfragoso731
It is still syncing the entire folder
Could you please export the task setting to a file and send it to risefly(a)risefly.com.
So we can investigate the problem.
Rosario91
Post by Rosario91 »
i faced this issue a couple of times, but it didn't really bother me
still nice to know there is a solution
The cause of this problem may be the system time of one of the two computers is not correct.
Please check the system time of the two computers that need to be synchronized.
