compression without encryption
denovo
Postby denovo » Thu Mar 16, 2017 1:42 am
Is it possible to have compression without encryption. I would like to compress files as I back them up, but I do not want to have them encrypted.
Re: compression without encryption
Postby RiseFly » Fri Mar 17, 2017 11:50 am
You can setup too tasks.
One synchronizes the folder with a zip archive file, and the another synchronizes the folder that contains the zip archive file with the target folder.
denovo
Postby denovo » Mon Mar 20, 2017 9:51 pm
When you write "One synchronizes the folder with a zip archive file", how do you do that. We have only found how to enable compression on the compression tab, which requires encryption. Can you send a link with documentation how to "synchronizes the folder with a zip archive file"
Postby RiseFly » Tue Mar 21, 2017 3:01 pm
Here is the help link about how to sync a folder with a ZIP archive:
http://www.risefly.com/help/wz_br_zip.htm
denovo
Postby denovo » Sun Apr 09, 2017 7:29 pm
This solution is not sufficient. It will move the entire zip file every time as we update it with new files. At least as far as I understand. We have lots of large files (20GB or greater database backups) that we want to simply zip each one and upload the zip. In the scheme you describe, the large files will be synchronized to a zip file and then the zip will contain lots of backups. Then it will upload the entire zip every time.
It would be a lot more straightforrward if on the "compression and encryption" you just allowed to compress with plain zip without encryption.
Postby RiseFly » Tue Apr 11, 2017 1:30 pm
Sorry, BestSync does not support compression without encryption feature.
