fail to view log after job successful
Posted: Mon May 23, 2016 9:03 am
by desmondchen
Dear Sir
I can't figure out. why does some job can "view log" then some job can't?
pls somebody help me.
Version:11.0.1.1
os:2008 R2 x64
Re: fail to view log after job successful
Posted: Tue May 24, 2016 9:52 am
Please enable log options in the "Log" settings of the task.
Check the "Record the log data for the log view window.".
Posted: Wed May 25, 2016 4:03 am
by desmondchen
Thank you for your reply.
I have enabled "Log" option of the task, but the status same as before.
Enable two option:
1. Record the log data for the log view windows
2. Export log data to following files:
Posted: Fri May 27, 2016 1:48 pm
The log will be recorded if some files are copied, or error happens.
Please try to change a file, then run the sync-task. The log must be recorded.
