Set task Priority
Posted: Thu Apr 09, 2015 12:35 pm
by svpr
BestSync 2015 ver.10.0.2.1 (64 bit)
OS: Windows 7 x64
In the context menu of Task List there is an item “Task Priority”, but when I select options “Below Normal” or “Idle”, then after some time I see that priority once again became “Normal”. How do I configure priority the Synchronization Task (Service) so that it has not changed?
My files are located at the production server and important for me to sync files had a lower priority than the main tasks and did not lead to a significant increase in the load on the server.
Re: Set task Priority
Posted: Thu Apr 09, 2015 1:37 pm
You can config the Task Priority in "Copy Options" setting tab of the task.
Posted: Fri Apr 10, 2015 5:55 am
by svpr
Thank you! I missed this setting.
