Preview Window shows non zero Completed Num before any syncing
ds00424
Postby ds00424 » Mon Dec 02, 2019 10:41 pm
Hi Again.
V14.0.1.6
I run the preview and get all the out of sync items (a lot - 742).
At this point Total Num = 742, Completed Num = 0 and Filtered Num = 4117 and all items are checked.
If I uncheck a directory of files (so as to not sync them) the numbers change as follows:
Total Num = 737, Completed Num = 82 and Filtered Num = 4107
In case it matters, the directory that was unchecked had 5 files in it in a few sub directories.
The Completed Num is concerning.
The change in Filtered Num, not so concerning, but perhaps worth looking into / explaining.
The change in Total Num seems correct.
In checking an unchecking some things in the Preview window, it seems like Completed Num decreases by 1 when a directory on the source side is NOT on the target side and is unchecked.
When only files that exist on both sides are checked, the Completed Num=0.
BTW, after Filtered Num changes the first time, it did not change again.
HTH.
ds00424
Re: Preview Window shows non zero Completed Num before any syncing
Postby ds00424 » Mon Dec 02, 2019 10:47 pm
A little more.
In the preview window I had it down to 2 files to sync.
Total Num = 2, Completed Num = 0 and Filtered Num = 4107
I then did the sync. It took a while for the first file to complete (possible my previous post?) and then the second completed quickly.
However the stats now say:
Total Num = 4107, Completed Num = 567 and Filtered Num = 4107
That is a little scary as i really hope it only synced 2 files and NOT 567 files.
From the output, it looks like only my 2 files were synced (sigh), but the stats should be corrected.
thx.
Postby RiseFly » Tue Dec 03, 2019 10:49 pm
Are you using the real-time sync feature?
When real-time sync is running, there are synchronized files. If you check/uncheck folder or files, the Completed Num changes.
ds00424
Postby ds00424 » Mon Jan 13, 2020 3:01 pm
Sry for the delay. Travel and holidays...
No this is not real time sync. This is on demand.
With previous version (I think I was on 2013), this worked as expected.
