BestSync Sync
zeus1976
BestSync Sync
Post by zeus1976 »
Hello togehter
In the last few days I noticed that BestSnyc not synced only the changes, but it synced everything. What am I doing wrong?
Before everthing was working fine. I'm working mit BestSnyc 2014.
Thank you for your Feedback.
Best regards
Re: BestSync Sync
What file systems the task is synchronizing with?
If one of the file systems is FAT, or FTP folder, and if you have not selected "Ignore file timestamp change caused Daylight Savint Time (DST) change" option in "Filter" Tab, then BestSync may synchronize every file over when the daylight saving time changes.
zeus1976
Re: BestSync Sync
Post by zeus1976 »
The Sync is from a NAS System to a SFTP Server. I have the same symptom with changing the "Daylight Savint Time".
Do you know another reason?
Best regards
Re: BestSync Sync
Both the NAS and SFTP may use FAT file system, so you'd better select "Ignore file timestamp change caused Daylight Saving Time (DST) change" option in "Filter" Tab.
zeus1976
Re: BestSync Sync
Post by zeus1976 »
I did but i have still the same problem.
Do you know another solution?
Thx best regards
Re: BestSync Sync
May be you can try "Action"/"Customized Preview"/"Synchronize Timestamp Only" to start the preview, then press the "Start" button to synchronize the timestamp of the local files and the remote files. After the timestamp is synchronized, BestSync can detected the changed file from the next synchronization time.
