Error connecting to S3
24Seven
Post by 24Seven »
I'm getting the following error when I try to setup a sync job to S3:
The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
I have already run regcloud.bat using "Run As Administrator" and this is on a Windows 2008 x64 R2 server. I get this error when I try to browse the folders in my S3 bucket.
24Seven
Re: Error connecting to S3
Post by 24Seven »
Found the problem. BestSync does not like EU buckets with periods in the name. Might also be that EU buckets simply cannot work over https when they have periods in the name.
I have tested the EN storage, BestSync can copy files with Umlauts characters.
