Files with special characters in filename, not synchronized
guptanikesh
Post by guptanikesh »
Files with the German/Swedish/Danish and other European language characters in file-name are not synchronized successfully from the network to local computer. After synchronization for the same file, two files(with extensions .BS_ and .BS_.slice_) are left in the local folder.
How can I fix the problem? How to make it possible that all the files are synchronized successfully??
Thanks a lot in advance
NIkesh
Re: Files with special characters in filename, not synchroni
If you are using FTP synchronization, please setup the "Advanced" option of the task by click "Advanced..." button in the "General" setting page. Please select the correct code page of the Server, usually, it is "UTF-8".
guptanikesh
I am using SFTP synchronization and in the Advanced option I have setup up the code page for server to "UTF-8" but it is not working. Please help me to fix it.
Thanks in advance
Please confirm if you are using the lastest version 6.2.43.
