Best sync syncs already synced files
Henrik4223
Postby Henrik4223 » Fri Nov 04, 2011 6:58 pm
Ever since it turned to winter time my sync jobs starts over and over again even though I have already synced the files (not cool when it starts syncing 4TB of data again). I have the same time on both the server and client, and I am not using any time settings as filter.
Any suggestions.
Re: Best sync syncs already synced files
Postby RiseFly » Sat Nov 05, 2011 1:42 am
This issue may be because the file system on the sever is FAT, and your server does not support getting /setting accurate file time. If this symptom happens, please use the "Action"/"Customized Preview"/"Synchronize Timestamp only" menu to synchronize the timestamp once.
Henrik4223
Postby Henrik4223 » Sat Nov 05, 2011 6:40 am
Both servers use nfts (files are above 4 GB). Server is Synology and client W7. Brfore winter time everything worked fine according to the logs.
Henrik4223
Postby Henrik4223 » Sat Nov 05, 2011 7:17 am
I tried the timestamp thing, but after scanning the files nothing happens. I experience this everytime I have the preview window open. Normally I can just close the preview window and the files are synced but that is not possible with the timestamp option as this stops the task.
Henrik4223
Postby Henrik4223 » Sat Nov 05, 2011 1:38 pm
Sorry I forhold to pres play to get the timestamp rhing to workshops.
The timestamp Thing works perfekt for the big files sync, but for my encrypted pictures it does not. IT keeps start over every time.?
Postby RiseFly » Sun Nov 06, 2011 1:33 am
What timezone are you living? How many minutes difference between the normal time and the winnter time?
Henrik4223
Postby Henrik4223 » Sun Nov 06, 2011 11:06 am
+ 1 Europa time (Copenhagen) - 60 minutes.
Postby RiseFly » Sun Nov 06, 2011 10:17 pm
When you start the preview window, please compare the time difference of the files that will be copied again.
What is the time difference of these files?
If you could give me a test account (email to risefly@risefly.com), I would like to debug this issue.
Henrik4223
Postby Henrik4223 » Mon Nov 07, 2011 12:29 pm
For files not yet synced it says:
31-12-1999-23:00:00 > 31-12-1999-00:00:00
I will once again check ther servers time.....
Henrik4223
Postby Henrik4223 » Tue Nov 08, 2011 6:37 am
The owner of the server has not checked the time out yet (again), but it must be a winter time issue.
The problem is that in my upload of small files it keeps copying all the files even though I now have checked the "Ignore file date&time changes that are because og Daylight Savings Time (DST))?
