Reat Time- Stops Svr 2008 64 Bit to Svr 2003 32Bit
Romee29608
Post by Romee29608 »
Server 2008 64Bit TO Server 2003 32 Bit - Real time set to Run as a Service will stop functioning after encountering an Failed update to the Folder2. My version is 6.2.30 (64Bit)
LOG INFO
APP:2011/10/03-07:55:41,***** BestSync start ****
OS Version:Windows Server 2008 R2 Standard Edition, 64-bit Service Pack 1 (build 7601)
BestSync Version:English Version Ver6.2.3.0
SVC:2011/10/03-07:55:46,Service started.
SVC:2011/10/03-07:55:46,***** BestSync Service start ****
BestSync Version:Ver6.2.3.0
SVC:2011/10/03-07:55:46,Reload Setting File.
SVC:2011/10/03-07:55:46,Load setting file [C:\ProgramData\RiseFly\BestSync 2011\service.fsf] is successfully.
SVC:2011/10/03-07:56:29,Create VSS Successfully--[E:\SHARE\].
SVC:2011/10/03-07:56:29,Start task:E:\SHARE\ ==> \\Server2\share\
SVC:2011/10/03-07:56:29,Start task by schedule.
SVC:2011/10/03-09:26:58,Task Result: E:\SHARE\ ==> \\Server2\share\ (Success=1287, Failed=270)
SVC:2011/10/03-09:26:58,End Task -E:\SHARE\ ==> \\Server2\share\
SVC:2011/10/03-09:28:29,Create VSS Successfully--[E:\SHARE\].
SVC:2011/10/03-09:28:29,Start task:E:\SHARE\ ==> \\Server2\share\
SVC:2011/10/03-09:28:29,Start task by schedule.
SVC:2011/10/03-09:57:08,Task Result: E:\SHARE\ ==> \\Server2\share\ (Success=1204, Failed=362)
SVC:2011/10/03-09:57:08,End Task -E:\SHARE\ ==> \\Server2\share\
SVC:2011/10/03-10:00:32,Create VSS Successfully--[E:\SHARE\].
SVC:2011/10/03-10:00:32,Start task:E:\SHARE\ ==> \\Server2\share\
SVC:2011/10/03-10:00:32,Start task by schedule.
Re: Reat Time- Stops Svr 2008 64 Bit to Svr 2003 32Bit
May be the failed items are not critical, please stop the task, and start the preview of the task to see the detailed error results.
