Strange errors in Logfile
escamoteur
Post by escamoteur »
while Syncing with SFTP I see ocassionally this error messages although everything seems to work right.
What does this mean?
Best
Tom
[1]
[5]C:\Users\ESCAMO~1\AppData\Local\Temp\BestSync.tmp\@23CFD093A062B2E6AF04CC01@@Dr. Volmer~(002F2193).msg
[1]C:\Users\ESCAMO~1\AppData\Local\Temp\BestSync.tmp\@3EC47BDCB03C1AD92A90C701@@Dr. Optics~(002F218F).msg
[2]C:\Users\ESCAMO~1\AppData\Local\Temp\BestSync.tmp\@23CFD093002249917D13CB01@@Dr. Volmer~(002F2190).msg
[4]C:\Users\ESCAMO~1\AppData\Local\Temp\BestSync.tmp\@23CFD093704D752E115CCB01@@Dr. Volmer~(002F2192).msg
[3]C:\Users\ESCAMO~1\AppData\Local\Temp\BestSync.tmp\@23CFD093304919A80FEECA01@@Dr. Volmer~(002F2191).msg
[5]
[5] RemoveFile:
[5] filename: /is/htdocs/wp1105184_X0CW9HFB94/outlook/@DefStore/@Appointments@Kalender/@23CFD093A062B2E6AF04CC01@@Dr. Volmer.msg
[5] StatusResponse:
[5] Request: FXP_REMOVE
[5] StatusCode: 2
[5] StatusMessage: No such file
[5] Failed.
[5]
[1]
[1] RemoveFile:
[1] filename: /is/htdocs/wp1105184_X0CW9HFB94/outlook/@DefStore/@Appointments@Kalender/@3EC47BDCB03C1AD92A90C701@@Dr. Optics.msg
[1] StatusResponse:
[1] Request: FXP_REMOVE
[1] StatusCode: 2
[1] StatusMessage: No such file
[1] Failed.
[1]
[4]
[4] RemoveFile:
[4] filename: /is/htdocs/wp1105184_X0CW9HFB94/outlook/@DefStore/@Appointments@Kalender/@23CFD093704D752E115CCB01@@Dr. Volmer.msg
[4] StatusResponse:
[4] Request: FXP_REMOVE
[4] StatusCode: 2
[4] StatusMessage: No such file
[4] Failed.
[4]
[3]
[3] RemoveFile:
[3] filename: /is/htdocs/wp1105184_X0CW9HFB94/outlook/@DefStore/@Appointments@Kalender/@23CFD093304919A80FEECA01@@Dr. Volmer.msg
[3] StatusResponse:
[3] Request: FXP_REMOVE
[3] StatusCode: 2
[3] StatusMessage: No such file
[3] Failed.
[3]
[2]
[2] RemoveFile:
[2] filename: /is/htdocs/wp1105184_X0CW9HFB94/outlook/@DefStore/@Appointments@Kalender/@23CFD093002249917D13CB01@@Dr. Volmer.msg
[2] StatusResponse:
[2] Request: FXP_REMOVE
[2] StatusCode: 2
[2] StatusMessage: No such file
[2] Failed.
[2]
[1]C:\Users\ESCAMO~1\AppData\Local\Temp\BestSync.tmp\@23CFD093C035AD7A56E1CB01@@Dr. Volmer~(002F2195).msg
[2]C:\Users\ESCAMO~1\AppData\Local\Temp\BestSync.tmp\@B36EA12B00D5CBD52A90C701@@Dr. Waldvogel~(002F2194).msg
[3]C:\Users\ESCAMO~1\AppData\Local\Temp\BestSync.tmp\@B36EA12B3049EAC7F88FC701@@Dr. Waldvogel~(002F2196).msg
[4]C:\Users\ESCAMO~1\AppData\Local\Temp\BestSync.tmp\@B36EA12BC0999143FA8FC701@@Dr. Waldvogel~(002F2197).msg
[5]C:\Users\ESCAMO~1\AppData\Local\Temp\BestSync.tmp\@B36EA12BF0EFD8D12A90C701@@Dr. Waldvogel~(002F2198).msg
[3]
[3] RemoveFile:
[3] filename: /is/htdocs/wp1105184_X0CW9HFB94/outlook/@DefStore/@Appointments@Kalender/@B36EA12B3049EAC7F88FC701@@Dr. Waldvogel.msg
[3] StatusResponse:
[3] StatusCode: 2
[3] Failed.
[3]
[2]
[2] RemoveFile:
[2] filename: /is/htdocs/wp1105184_X0CW9HFB94/outlook/@DefStore/@Appointments@Kalender/@B36EA12B00D5CBD52A90C701@@Dr. Waldvogel.msg
[2] StatusResponse:
[2] StatusCode: 2
[2] Failed.
[2]
[1]
[1] RemoveFile:
[1] filename: /is/htdocs/wp1105184_X0CW9HFB94/outlook/@DefStore/@Appointments@Kalender/@23CFD093C035AD7A56E1CB01@@Dr. Volmer.msg
[1] StatusResponse:
[1] StatusCode: 2
[1] Failed.
[1]
[4]
[4] RemoveFile:
[4] filename: /is/htdocs/wp1105184_X0CW9HFB94/outlook/@DefStore/@Appointments@Kalender/@B36EA12BC0999143FA8FC701@@Dr. Waldvogel.msg
[4] StatusResponse:
[4] StatusCode: 2
[4] Failed.
[4]
[5]
[5] RemoveFile:
[5] filename: /is/htdocs/wp1105184_X0CW9HFB94/outlook/@DefStore/@Appointments@Kalender/@B36EA12BF0EFD8D12A90C701@@Dr. Waldvogel.msg
[5] StatusResponse:
[5] StatusCode: 2
Re: Strange errors in Logfile
The error means Bestsync try to remove a file but the file does not exist in the server.
If there are two PCs synchronize with ONE folder in server, may be the file has been deleted by another PC before this PC trying to delete it.
Maybe you can just ignore this error if the synchronization works.
