Purging Redundant Language Files
alan9876
Post by alan9876 »
64 Bit BestSync 6.1.1.0 Portable
There are 15 files BestSyncApp with extensions 040c through to 0804.
Is English built into the main code, or do I need to retain one of those files, and which one ?
Is it safe to remove the redundant files ?
Alan
Re: Purging Redundant Language Files
040c ~ 0804 is the language ID, you can find the language ID at the following webpage.
http://support.microsoft.com/kb/246664/en-us
You can delete the language files that are not necessary for you. If you delete all the language files, the default UI is English.
alan9876
Post by alan9876 »
Many Thanks
I like to economise on disk space, and also the quantity of files.
I use the Quad file explorer Q-DIR and like to see all the relevant files without having to scroll past languages.
Many applications are much worse with 50+ language files.
Alan
