Preview when USB drive inserted
ttom
Post by ttom »
Can we have a new option to start preview, instead of sync, automatically when a USB drive is inserted? It will be useful to reduce manual operations, but allow the option to decide sync options.
Re: Preview when USB drive inserted
The current version has not this option.
If you need preview, please start the preview before you insert the USB disk. The preview window will monitor whether the disk is mounted.
ttom
Post by ttom »
Well, that means I need to open the main window, select the corresponding task, click the preview button, and then leave the preview window open all the time..
Is it possible to get the option built in?
We have considered to add this option, but you see there is no space for this kind of option in the "Schedule" setting tab.
ttom
Post by ttom »
That is weird.. that tab has more than 2/3 of the space empty..
If you check "Designate a schedule", the left 2/3 space will be used.
