Application to run before synchronization
mikecarle
Post by mikecarle »
I'd like to suggest an enhancement for the feature "Application to run before synchronization": an option like "Sync only if the returned ErrorLevel is 0" would be great. Then, I could run my own "application" to check, whether the sync should really be done or not (I am having trouble with network drives, which are not usable although they are there - and I could solve this by running my own application before to check whether sync would work or not).
Regards,
Mike
Re: Application to run before synchronization
Thank you for the good suggestion, we'll consider add this option in the future version.
