bestsyn 2020: unable to expand sync log
gracelim
Postby gracelim » Fri Aug 14, 2020 6:55 am
hi ,
i have upgraded my bestsync2019 to bestsync2020 in windows 10 and windows 2003. i noticed for tasks that are set to realtime sync,
1. when i open the log view and tries
to expand the most current sync log row (last row), it does not expand.
2. when i open the log view and the last row is already expanded, and tried to collapse and expand again, it will not expand anymore.
3. previous sync log rows sometimes it expand and sometimes it wont expand
any idea how to go about it as i need to check the logs
thanks
grace
Re: bestsyn 2020: unable to expand sync log
Postby RiseFly » Fri Aug 14, 2020 12:16 pm
The cause of this issue is that BestSync does not save the log immediately after files are synchronized in real-time mode.
The saving period can be set in "Period for send email or exporting log file" in "Miscellaneous" tab.
gracelim
Postby gracelim » Fri Aug 14, 2020 2:55 pm
i stop the task and click view log , same behavior occurs. is this normal even the task is stop?
gracelim
Postby RiseFly » Sat Aug 15, 2020 5:16 am
The View Log button is disabled, it means that the log data is not available.
Please confirm if you selected any "Log" option in the Task Setting.
"Log" tab /☑ "Record the log data for log view Window", or ☑ "Send Log data by e-mail"
gracelim
Postby gracelim » Sat Aug 15, 2020 2:31 pm
it is set to "Log" tab /☑ "Record the log data for log view Window"
the view log button is enabled .
Postby RiseFly » Sun Aug 16, 2020 12:01 am
The "View Log" button is grey out only because the log of the task does not exist.
Please try to change a file, let the task synchronize the file, then you can see the "View Log" button is enabled.
gracelim
Postby gracelim » Mon Aug 17, 2020 3:43 am
i am able to open the view log button. the problem is after opening the view log and try to expand lastest sync log row, it wont expand even there were files that have been transferred.
tried expanding the previous sync log rows that comes before the current sync log row , sometimes it will open and sometimes not.
noticed that i can only expand /collapse alternating rows. example: there 5 sync log rows (1 (old) to 5 (lastest))
i will be able to expand/collapse row 2 and 4 but not for 1,3,5
Postby RiseFly » Mon Aug 17, 2020 7:56 am
Because the task is using the real-time mode, to prevent the task from saving the log to frequently, BestSync saves the log by the period setting in the "Miscellaneous" tab. The option is "Period for sending email or exporting log file", may be you can set a shorter period to update the log more frequently.
Users browsing this forum: Steeler [Crawler] and 5 guests
