txt file contains ^M when it get transferred to linux server
gracelim
Re: txt file contains ^M when it get transferred to linux server
Postby gracelim » Fri Aug 14, 2020 3:57 pm
ok. will try
gracelim
Postby gracelim » Fri Aug 14, 2020 3:59 pm
ok. will try
Marnesunita
Contact:
Postby Marnesunita » Mon Aug 24, 2020 10:27 am
Great share!
gracelim
Postby gracelim » Sat Aug 29, 2020 9:37 am
we have upgraded to that version and still encounter the problem
when the problem occur, it is consistent for the extra line to appear on particular rows for some files everytime it generated for the whole day if there is no addition/removal of records.
by next day, incase there additional / removal of records... this problem may or may not occur.. once it occurs, extra line will appear on that same row. again
example for abc.csv (windows) it will always appear row 1697, 9420,17613 etc,,,
AA-BI~AA-BI~.005~JPS1~ (line# 1696)
AA-BI~AA-BI~.005~JRC1~ (line# 1697)
(liine# 1697) extra line
AA-BI~AA-BI~.005~JRC1~ (line# 1698)
gracelim
Postby gracelim » Thu Sep 03, 2020 4:39 am
extra line problem usually happens for 1mb and up file size.
any advise how to go about it?
gracelim
Postby gracelim » Thu Sep 03, 2020 6:38 am
correction it also happens to file size 50kbytes and up...
Rashimane
Contact:
Postby Rashimane » Thu Sep 03, 2020 10:30 am
Excellent sharing!
Postby RiseFly » Sat Sep 19, 2020 7:21 am
We have tested BestSync severely related to the ASCII conversion (converting Windows Carriage-return code to Linux Carriage-return code) .
You must select "ASCII Mode" in "Transfer Mode" of "Advanced" setting of the FTP folder.
gracelim
Postby gracelim » Mon Sep 21, 2020 12:49 am
"ASCII Mode" in "Transfer Mode" of "Advanced" setting of the FTP folder was selected and it is still occurring from time to time.
the files being send are system generated using pl/sql script thus no user is editing it.
Postby RiseFly » Mon Sep 21, 2020 3:03 am
If you find some files has the problem, may be this file are uploaded by an old version.
Please try to use the preview of the task, modify the synchronization-action to upload, upload the files again to see if the problem can be resolved.
