Onedrive Shared folder Conflict
vziogas
Postby vziogas » Mon Oct 23, 2017 10:21 pm
i need to sync an onedrive personal account with a desktop folder.
Everything works fine except the folders that others share with me.
In these folders, i can only download files and changes. when bestsync tries to sync (upload) my local files to the cloud i get a 409 conflict result.
How can i fix this problem?
Thanks in advance!
Re: Onedrive Shared folder Conflict
Postby RiseFly » Tue Oct 24, 2017 10:07 pm
Could you please post the log at the bottom of the preview of the task here?
vziogas
Postby vziogas » Thu Oct 26, 2017 7:34 pm
>POST /oauth20_token.srf
<200 OK
>GET /me/skydrive/files?limit=100&filter=folders
<200 OK
>GET /folder.5bae28a00542229e.F02B1E3CE55AC8E!4478
<200 OK
>GET /folder.5bae28a00542229e.F02B1E3CE55AC8E!4478/files?limit=100
<200 OK
>[1]POST /oauth20_token.srf
<[1]200 OK
>[1]GET /me/skydrive/files?limit=100&filter=folders
<[1]200 OK
Download file failed, can not find the file id.
>[1]GET /file.5bae28a00542229e.F02B1E3CE55AC8E!4479
>[2]POST /oauth20_token.srf
<[1]200 OK
<[2]200 OK
>[2]GET /me/skydrive/files?limit=100&filter=folders
<[2]200 OK
>[3]POST /oauth20_token.srf
<[3]200 OK
>[3]GET /me/skydrive/files?limit=100&filter=folders
<[3]200 OK
>[4]POST /oauth20_token.srf
<[4]200 OK
>[4]GET /me/skydrive/files?limit=100&filter=folders
<[4]200 OK
>[5]POST /oauth20_token.srf
<[5]200 OK
>[5]GET /me/skydrive/files?limit=100&filter=folders
<[5]200 OK
>[6]POST /oauth20_token.srf
<[6]200 OK
>[6]GET /me/skydrive/files?limit=100&filter=folders
<[6]200 OK
>[7]POST /oauth20_token.srf
<[7]200 OK
>[7]GET /me/skydrive/files?limit=100&filter=folders
<[7]200 OK
>[2]GET /file.5bae28a00542229e.F02B1E3CE55AC8E!5116
>[3]GET /file.5bae28a00542229e.F02B1E3CE55AC8E!5788
>[7]GET /file.5bae28a00542229e.F02B1E3CE55AC8E!5779
<[2]200 OK
<[3]200 OK
<[7]200 OK
vziogas
Postby vziogas » Thu Oct 26, 2017 7:36 pm
And here is the log after the synchronization
(there are 3 files not synchronized from my desktop to my onedrive shared (from others) folder)
<200 OK
<200 OK
<200 OK
<200 OK
<[1]200 OK
<[1]200 OK
<[1]200 OK
<[2]200 OK
<[2]200 OK
<[3]200 OK
<[3]200 OK
<[4]200 OK
<[4]200 OK
<[5]200 OK
<[5]200 OK
<[6]200 OK
<[6]200 OK
<[7]200 OK
<[7]200 OK
<[2]200 OK
<[3]200 OK
<[7]200 OK
<200 OK
>[2]Upload /Last test viz/proxiro koufomata.pdf
>[2]PUT /folder.5bae28a00542229e.F02B1E3CE55AC8E!4478/files/proxiro%20koufomata.pdf
>[3]Upload /Last test viz/samsonite.txt
>[3]PUT /folder.5bae28a00542229e.F02B1E3CE55AC8E!4478/files/samsonite.txt
>[1]Upload /Last test viz/Memo Style Train.pdf
>[1]PUT /folder.5bae28a00542229e.F02B1E3CE55AC8E!4478/files/Memo%20Style%20Train.pdf
[2]409 Conflict
[2]Conflict
[3]409 Conflict
[3]Conflict
[1]409 Conflict
[1]Conflict
[3]409 Conflict
[3]Conflict
[1]409 Conflict
[1]Conflict
[2]409 Conflict
[2]Conflict
[3]409 Conflict
[3]Conflict
[1]409 Conflict
[1]Conflict
[2]409 Conflict
[2]Conflict
Saving the meta data.
>Upload /Last test viz/_BestSync_Meta.dat_
>PUT /folder.5bae28a00542229e.F02B1E3CE55AC8E!4478/files/_BestSync_Meta.dat_
409 Conflict
Conflict
Postby RiseFly » Mon Oct 30, 2017 11:48 am
Please confirm from the owner of the shared the folder to see if you have the writing privilege to the shared folder.
vziogas
Postby vziogas » Mon Oct 30, 2017 8:07 pm
I confirm that i have the writing (edit) privilege of the shared folder.
i can see it in the onedrive online platform, the owner also confirmed and when i change things or upload sth to this folder using the online onedrive platform it works.
Postby RiseFly » Mon Nov 06, 2017 1:54 pm
I'm regret to tell you that BestSync does not support synchronizing with shared folders of others now.
As alternative way, please synchronize with your folders and share them instead.
vziogas
Postby vziogas » Mon Nov 06, 2017 8:02 pm
Thank you for the information.
Hope you can add it to the next update!
Branders
Postby Branders » Sun Jan 07, 2018 9:54 am
Anyone know if it will be added in the next update?
