Warning : failed to set time
ewadrel
Postby ewadrel » Mon Feb 01, 2016 3:59 pm
I bought your software.
I keep having and error when synchronizing 2 folders :
"Warning : failed to set time." And backup fails.
Please help me and tell me how to fix the problem.
best,
PCombet
Re: Warning : failed to set time
Postby RiseFly » Tue Feb 02, 2016 12:49 pm
"Warning : failed to set time" means that the file system has not the feature of setting the last modified time.
BestSync can still synchronize with the file system correctly, but it is better if you use a file system that supports modifying the last modified time.
ewadrel
Postby ewadrel » Wed Feb 03, 2016 11:25 am
thank you for your answer.
What file system should I use to be able to modify the "last modified time" ? (on Linux and Windows)
Thx,
Philippe
Postby RiseFly » Wed Feb 03, 2016 10:22 pm
Could you please export the task setting to a file then send it to risefly@risefly.com, so that we can give you more advice.
Few FTP servers and a few cloud storages do not support "setting file time". FAT, NTFS, Network Drives support "setting file time".
