Windows rightclick menu de/encryption function...
larsahlstrom
Contact:
Postby larsahlstrom » Tue Jan 26, 2016 1:08 am
...is very good, I use it a lot. Simple, an functional.
Except for one thing...suddenly these two lines are gone...
And I cannot figure out how they could be re-enabled.
I guess this i simple, and it COULD have something to do with another task I have installed, the "TuneUp Utilities" from AVG.
I'm in the process to get rid of that, as my Windows Security backup has gone to the movies, as well as the update function. :)
But if you know a enable disable switch of the context menu list, I would be grateful. It could help me in this troubleshooting.
Thank you! And thanks for a very good app! :)
Best regards,
Lars
Re: Windows rightclick menu de/encryption function...
Postby RiseFly » Wed Jan 27, 2016 9:20 am
In the install folder (C:\Program Files\RiseFly\BestSync), there is a dll called BestSyncExt.dll.
Run following command line can register or unregister the shell context menu.
1. Start the command prompt by Administrator.
2. Change the folder to the install folder.
cd C:\Program Files\RiseFly\BestSync
3. Run the following command line to show the shell context menu.
regsvr32 BestSyncExt.dll
4. Run the following command line to hide the shell context menu.
regsvr32 /u BestSyncExt.dll
Users browsing this forum: No registered users and 8 guests
