Sync Issues to an FTP
quazl
Post by quazl »
I am having an issue with a sync job on a new sever.
It is a simple sync of a local folder to an FTP. It has completed successfully, but now when I re run the sync it thinks that ALL the files need to be resynced. I have created and recreated the project to see if that would help, but it still wants to sync all the files. It is a default sync job without any backups. I am able to right click any of the files at random and show the files in both folder sources and and can confirm that they exist on the local source and the ftp source.
How do I fix or troubleshoot this issue?
Re: Sync Issues to an FTP
Could you please export the task setting then send it to risefly@risefly.com, so that I can give you advice?
Thank you for the exported task setting.
I have tested the task, BestSync can synchronize with your server without problem.
But the server refused to execute MFMT command that BestSync uses to set the timestamp of uploaded files, please check the setting of the server to allow MFMT command.
