css file mimetype
Shimon
css file mimetype
Post by Shimon »
Problem on Trial usage of BestSync with S3:
It seems a bug in BestSync, since it does not keep the correct css MIME-type on S3.
Synchronizing .css files with S3 made the files unusable by HTML, because "text/css" MIME type not set.
Please advise,
Thanks,
Shimon
Re: css file mimetype
Please try BestSync 2015. Bestsync 2015 must have fixed this problem.
Shimon
Post by Shimon »
Problem solved with BestSync 2015. Thanks.
Shimon
Post by Shimon »
Too soon to report problem solved.
BestSync 2015 DID NOT solve the problem.
Your Advise please.
Shimon
Have you tried to upload css files again by BestSync 2015?
You can start the preview of the task, change the actions to Copy from local to S3, then press the Start button to upload files manually.
