Good morning, I have installed last years bestsync 2019, now I would like to know if protocol tls 1.2 is supported or not. Because is required by the software that will recive the files.
Thank you
Davide
						Protocol TLS 1.2
Re: Protocol TLS 1.2
What kind of file systems is the task synchronizing?
If it FTP etc, BestSync will hand-shake with the server and use the proper TLS/SSL protocol.
I use SFTP, i know the handshake is TlS/SSL i would like to konw if tls 1.2 is supported
Sorry probably I don't understand well, I use windows 2008 server, so depends by operating system
Is correct?
						Is correct?
Informative share!
FTPS(FTP over Implicit SSL)/FTPES(FTP over Explicit SSL) uses the Windows SSL library, so it must support TLS1.2.
Here is the document about how to enable TLS1.2:
https://docs.microsoft.com/ja-jp/mem/co ... le-tls-1-2
				Shivamraut
- Contact:
Great share!
